David Womby
I need some VERY basic advice. Keep the explanations simple, please, because I am a complete newbie to V8s and 4bbl carbs. My engine experience before has only been on Jaguar L6 EFI engines.
My car (1964 Bristol 408) has the following installed:
1978 Monaco 360 engine.
Mopar Performance Cam 4452761.
Summit Racing Carb SUM-M08600VS.
Distributor Pertronix PNX-D141701.
Coil Pertronix PNX-45001.
The exhaust manifolds are stock iron castings.
The car runs fine at all speeds. It lopes more loudly at idle than I would like but I think that's due to the cam. My main problem is it uses a lot of gas (less than 10mpg) and the exhaust smells of it. I assume it's too rich but I always was taught to make sure thhe timing is right before adjusting the mixture. So, here's my questions:
1. What should the timing be for that cam and distributor combination?
2. How do most folks set the mixture on these carbs - vacuum gauge or by ear based on revs or what?
Thanks for any help.
David
David
