- 3:53 AM
- Feb 22, 2021
- Roswell, New Mexico
Hey all,
I'm getting close to registering my "specialty'
built truck. I'm going to attempt to install the
windshield glass in a pre-war (1940) two piece
windshield frame comprised of a upper and
lower section of frame with a divider in the
center. The frame is mounted to the truck via
two hinges at the top, with a center mounted
crank mounted at the bottom that allows the
windshield frame to tilt outward. There is a gasket
installed around the outside perimeter of of the
frame, but unlike modern times, it's not to hold
the frame in place, but only acts as a seal.
Modern day glass shops use a setting tape to
secure the pane in the frame. I'm pretty sure
OEM didn't use a setting tape, but instead used
a glazing compound, as it took two days with
a small screwdriver to dig the old "stuff?" out.
Since the glass shops around here want a
minimum of $200 just to set the panes, I'd like
to attempt to do this on my own, but not knowing
the tolerances involved with setting tape, I'd be
inclined to use what the old schoolers did.
Your thoughts?
Your thoughts?
