- 8:42 AM
- Sep 17, 2021
- central Illinois
I'm at the dentist.
I hate going to the dentist, even for an exam.
I'm at the dentist.
More doors less room, I think. Bought bottom freezers with a rollout basket.No adjustment on the doors.
Amana brand (same as whirlpool IIRC).
The trim plugs on the top to cover the unused hinge bolt holes were glued in and glued on.
I broke 2 of the 3 and bent the 3rd. Had to drill them out. WTF?
Guess I'll get some shallow head Phillips machine thread screws so the holes don't fill up with crap.
When we bought it, we were on the low end aisle and bet on what the most expensive model was. Wife said 3K, I sad 3250. WRONG.
$3800
A side by side is definitely a different experience.
Totally different mindset required for fitting stuff in.
I noticed they now have models with 4 doors, and the 4th one can be either frige or freezer.
Interesting.
Replaced a bummer tail light on the wife's Durango, 5 minutes and 130 bucks later it's done.
Was it the socket?
I've noticed on my Dakota, that the sockets are wearing in an odd way that causes to bulb to either not work or work intermittently if it's fully seated.
Pull it out a bit and it starts working.
I've replaced both turn sockets on the front and I think the backup light sockets have the same issue.
Sounds like an issue with your sciatic nerveTrying to get the interior of the house painted, but with a gimp hip & leg. I wind up suffering from burnout & pain after about 3+ hours of work. It'll eventually get done. I do have back issues, but never has it effected my hip & leg like this. I'd like to know what the hell it is?
@MarParLol, as a guy who did a lot of o-**** compliance work, you don’t need guard rails or fall protection until the scaffold is 10 feet high. Some might say “hey it’s 6-feet”; nope 10 when on a scaffold. O-shitsters would likely give ya…well…**** with how it’s supported. But – then they couldn’t unless you’re an employer having employees working from it. Used to piss-off the contractors having employees cuz self-employed contractors were exempt from osha.Still here.. my OSHA approved scaffolding..
Went to the local butcher to grab a stack of vac-packed steaks for the summer shutdown period....they close for a couple of weeks, and I hate supermarket steaks.
The bastages hide the gristle and fat under the steak.
I need to move closer to Illinois so that Mario can take care of my meat needs.@MarPar
See if anyone in your area specializes in MFR[ myo fascial release] massage therapy. 3 years or so ago, had actually been bothering me for much longer, I thought I needed to get a hip joint replaced on the left. Pain was ffn excruciating, especially after spending the day creeper diving. I was able to get in and see a gal in Cambria who specializes in MFR and it was like the switch had been shut off finally on the pain. Our bodies are covered top to bottom with Fascia which is like a ballistic mesh. When it gets irritated, it bunches up and does not release. Chiro does not address this. Its not a one shot deal on the treatments as if you are like me, you spent a lifetime acquiring injuries that attribute to having a body out of whack. My right side is down at the shoulder and torqued forward enough that there is a difference in leg length when laying down. Getting this addressed equals it up. I'm jacked up enough that the gal in Cambria hooked me up with two friends of hers that do tandem treatments. Dorothy did not have enough limbs to apply correction to multiple areas at the same time. I need to get back to the chicks for more but need to wait until I'm more flush with cash. Insurance does not cover this for me.No, this is lower than that. It's more of a hip/groin issue, the ball & socket of my hip has popped as well as in the hip area that just kills all muscle strength in my thigh, butt, hip & groin area. Even sends pain down to the bottom of my foot. I need to see a Chiro but hate going to them when in pain as I don't get a good adjustment.
Have a cheap Frigidaire that needs to be adjusted but looks to me it's built like a piece of junk and so long as the doors close good enough to not leak, I'm going to leave it be. It's a shop box anyways....
