Jeff Erwin
71 sbee, 440x6. Running very well. However, I am not sure what the PVC port on the center carb is supposed to do. Actually I know it's 'supposed' to tie to the driver-side valve cover to draw gasses back into the intake to be burned but my valve covers don't have a port for that. So the PVC port on the center carb, which I assume is an intake and not a source of vacuum, is connected via vacuum hose to one of the two vacuum ports on the power brake canister. The other side of the brake canister goes to the output of the vacuum canister, meaning I think I am applying vacuum to the carb PVC port. The vacuum canister input comes from the manifold vacuum port on the back of the intake manifold. Plenty of vacuum at the vacuum canister and the brakes work great.
Sometimes I mentally decide this is all ok, but I have a nagging feeling that it isn't right. It seems like the routing I have is pulling from the center carb port which isn't the way it is supposed to work, I think. If I don't have a PVC valve on the valve cover, where should the PVC intake on the center carb be routed to?
The engine came this way, I am just now getting to the smaller details and I need to figure this one out.
