Can someone give me the short course on where to find VIN numbers
SteveSS
6:57 AM
Colorado Springs
When I search all the comes up is decoding the VIN tag or someone selling a matching numbers car. I want specific locations on where to look to see if I have a matching numbers car. 1969 Dodge Charger SE 383 AT.
#1 rad support
#2 drivers trunk gutter. For 69 I believe.
Lots and lots and lots of threads on this subject.
Dash Vin
Radiator support
Trunk lip, hidden under weather strip
Engine block Right side pan rail...
Transmission case, Auto = right side of bell housing on a flat pad, Manual right side of trans case on a flat pad...
Fender tag, bottom row to the far right
and the secret locations:lol:
rad support stamped on verticle part of upper tie kinda on drivers side but not extreme
trunk gutter drivers side need to pull rubber back a little above where rear valance seem meets quarter
motor and tranny close to pans
Dash Vin
Radiator support
A lot of of the best info is found here at
mmcdetroit.com
I have three 68’s and a rad support I cut out of a ‘68. On the St. Louis car it is on the back of the rad support facing the engine. Where is it on the Lynch Rd. cars? Is it under the antifreeze decal?
I have a St.Louis 69 and that's where mine is.
Not under unless someone did it different occasionally. Mine are next to it.
I don’t see it anywhere in the Lynch Rd. cars. I’ll have to check the trunk gutter on the 4 door. Not sure where they would have put it on the wagon. The St. Louis car has it prominently on the side facing the engine.
I wonder how the cops knew the number if the fender tag is missing? To my knowledge, Chrysler lost all records of 68’s. VIN’s and SON’s. 69’s and 70’s as well.
I have multiple MI 69 cars and it's on top of the radiator support.
My St. Lou '70 Charger has it on engine side of rad. support. Also, I don't recall anyone saying this location for a vin location. On driver door, mine has a taped vin#.
My ‘70 as well. And my ‘68 St. Louis car.
I don't mean on frame rails or radiator supports I mean specifically on the engine block, heads, manifold, transmission with pictures would help. Dadsbee, don't bee a Dickbee. If you don't want to help or read a post then F.O. I'm not in mood for it.
That’s not very nice...
I personally think the body #’s are more important than the block and transmission #’s. It’s too easy to just switch a drivetrain over to another body.
