Mike67
Look in your exhaust for the missing piece, header /collector/ manifold.As a follow up, if you will, I did not find the metal piece in the other head or intake but did find another plug with collapsed electrode. Is there anywhere that you suggest I look? Thanks again.
Definitley need to check your piston to valve clearance before reassmbling. KB recommmends .040". May need a thicker gasket.
