Attempting to use some shrink tube to seal up a leak on the shift cable of my 62 727. I have both 1/2 (2:1) and 5/8” (3:1) tube on hand. I thought I had seen a diagram showing the inside where the cable connects in my TM but apparently not. The directions say to use a screw driver to push on a spring clip that holds the cable end. Unfortunately I can’t see into the darn neutral safety hole to see anything. My exhaust keeps me from getting my fat head in that position.
So my questions are - if I had a diagram showing the point where the cable attaches inside the trans to see what I am dealing with could I poke a screwdriver in blind and depress the spring. If this is possible does anyone have said diagram?? Can the cable be reattached blind?
Since this probably isn’t the best approach I have the option of dropping the exhaust pipes so I can see into the hole. My other thought / question is if I were to take off the trans pan itself does this offer any better access to the cable connection to remove and to reinstall? I wouldn’t mind getting a look inside the trans / filter etc and installing a new pan gasket but if unless the removed pan offers a significant benefit for the cable work I’ll probably just drop the exhaust and go through the safety switch hole. Never worked on one of these cable shifters before. Any recommendations?
