Red63440
I ordered a Leed disk brake conversion to replace the front drum brakes on the Fury. With the engine, transmission and upgrade of the rear end housing and the addition of the differential completed the mechanical items. I ordered the kit through James at PST and received the FBBO discount and also found there was no tax added for a savings of a little over $161.00. The kit is 100% bolt on and uses the drum spindles and comes with everything needed to install included all hardware, hoses, brake lines, MC, adjustable rear brake valve, rotors, calipers and brackets. Leed brakes is in Cheektowaga, NY which is about 30 minutes from me so if I ever have a problem they are only a short drive.
