Some hippy flower child built the car from the factory,If it bothers you,send it to me.I will thank you for it.
What part # is on your oil pan?
As warranty was limited on the hemi,maybe this is a replacement under warranty n they used the paint to vertify this.Just a guess not sure??I've rebuilt plenty of engines in my day & I've never seen a painted crankshaft. Has anyone else seen one?
I’ve seen small splotches at times on all different manufacturers, but nothing as big as those.I've rebuilt plenty of engines in my day & I've never seen a painted crankshaft. Has anyone else seen one?
I'm sure you would mention a maltese cross. May a shift change? A frustrated artist?
I think it is a 547 6 qt if I rememberThe oil pan was replaced with this repop, which looks like a 68-69 Hemi pan. Don't know the reason why? There was no windage tray either. I had heard that the 66 pans had a smaller capacity; is that true? If so, maybe that's why it was replaced.
Where did you get the tail pipe hangers?
According to the previous owner, my crank was replaced under warranty. I haven't had the pan off to see if there's any paint on it.As warranty was limited on the hemi,maybe this is a replacement under warranty n they used the paint to vertify this.Just a guess not sure??
Mine is 5 qts, so 6 qt oil change with the filter.The oil pan was replaced with this repop, which looks like a 68-69 Hemi pan. Don't know the reason why? There was no windage tray either. I had heard that the 66 pans had a smaller capacity; is that true? If so, maybe that's why it was replaced.
I did the same thing for the same reason. Gave me a big advantage through lifeIt's what I learned on. Took typing in high school since the class was full of girls...
