I sent you a PM. Please check it out and get back to me when you can, I'd really appreciate it!Thank you. It was alot of work. I think the end result was well worth it. I didn't want a big ole pro stock scoop or a Chevy cowl induction hood at all. I like to be different.
, 383, shadetree buildup (aluminum dual plane intake, carb, hydraulic cam (284/.488? you know the thingMy 9.5:1 383 powered Super Bee with a 284/484 cam and 3.55 gears, 3 angle valve job 906 heads, factory converter, Hooker Super Comps, Torker intake, and hybrid 680/750 Holley was a mid 13 second car.
Shouldn't be terribly hard to get your slightly heavier Charger there without too much exotic equipment.
With a similar engine build, the 3.91 gear alone might do it.
No offense meant, but unless you have taken a bunch, and I mean A BUNCH, of weight out of your 68 charger, it will be closer to 4100, than 3100.This is encouraging because my set up is fairly similar to yours with the 3.91 gears, with more compression and (IMO) better heads Edelbrock RPM performer, better converter. I've taken a bit of weight off the car but still expect it to be 3100ish. Sadly, altitude is my killer up here in Denver. That's 7-8-tenth's right off the bat.
33 IMP is spot on, My 68 Charger is 4100lbs Race weight without a hood, now my car has AC, OD trans D60 rear,no way to get even close to 3100 unless you build a tube chassis race car with lots of fiberglass parts,No offense meant, but unless you have taken a bunch, and I mean A BUNCH, of weight out of your 68 charger, it will be closer to 4100, than 3100.
My stock 440 roadrunner is 3700, very likely lighter than your charger, and some fairly serious lightening got my 62 savoy (supposed to be the lightest b-body) down to 3250. Minor lightening of a 68 charger smallblock automatic? I'd guess 3650-up.
Factory weight is wrongThey come factory 3505 lbs? I've shed a solid 500. Put 230 back in for me that's where I'm getting my number. Is that factory number wrong?
And no offense taken at all lol. She's just as fat as I am haha I am very curious to know what it weighs now though lol Excited to get it on the scales soon.
What is your weight bias front to rear? Had lots of problems getting a big block Challenger to be consistent that had a lousy weight bias and finally just installed ladders and ding ding ding.We run them on the street and drive everywhere. What problem did you have with them?! Been 10.01 @ 133mph @ 3,700 lbs. on a 275. Zero issues and plant tires hard!
My Challenger is 3760 in full race/street trim at 54%. Depending how much power you are making. Today's higher horsepower vehicles are adding more nose weight to help keep the front ends down from power wheel stands.What is your weight bias front to rear? Had lots of problems getting a big block Challenger to be consistent that had a lousy weight bias and finally just installed ladders and ding ding ding.
52/48.What is your weight bias front to rear? Had lots of problems getting a big block Challenger to be consistent that had a lousy weight bias and finally just installed ladders and ding ding ding.
Yabbut! You've got 650hp at least, op is just trying to run 13s.lol. $1500 can be better spent elsewhere.I was able to get my old all iron hemi to launch well with caltracs and be super consistent and reliable. Drove it on the street as well!
View attachment 1250900 View attachment 1250901
