Paul_G
- 11:43 AM
- Dec 24, 2013
- Surprise, Arizona
Been chasing down many issues on the new to me 69 RR, 528 Hemi with with a Procharger.
This problem, the engine lays down after a few seconds of wot, like it drains the bowls and runs completely out of fuel. I experienced that, and do not not push it there again. Lean is bad. I have been looking at many things that can cause this. Electric fuel pump sizing may be a main factor.
No numbers are on the fuel pump thats on the car now. But it looks exactly like this one. https://www.summitracing.com/parts/crt-p5001
Spec; Designed to operate applications with system pressures between 9 and 22 psi, they are flow-rated at 50 gph at 20 psi.
Right on Summits site it gives a chart to help size a fuel pump.
https://help.summitracing.com/app/answers/detail/a_id/5245/~/what-size-fuel-pump-do-i-need?
I am going by 650HP, which is probably on the low side of a Pro Charged 528 Hemi. It says I need 67 gph for a carbed with power adder engine. The carter pump I have is only rated at 50GPH at 20psi. When the boost comes in, probably close to 20 psi. that pump cant even push fuel in to the bowls. Am I wrong?
