matthon
Yes, no other way.Are your backing plates mounted directly to the axle tube and then the axle flange is on the outside?
Axles come with flange that bolts to the axle tube placed on the axle before the bearings.
Bearings have a retainer built in that prevents the flange from coming off, as it holds the axle to the tube.
Backing plate has to go on first.
I also checked kryslerkid's thread, he has a 62 as well, same axles, documented the process with pics.
