1170 wheel HP at 19psiAnd the numbers?!?!?
That's some steam for sure!1170 wheel HP at 19psi
Nice power and beautifully done. Nice car.That's some steam for sure!
Update us with some pictures and info.Excellent numbers! My build is still in the tuning stages, but I got to drive it a bit last summer. If I can make it to 15# this year and it seems happy, I'll dyno it. I expect it will make 750+ to the wheel easy enough, maybe a bit more.
That’ll be a blast. I’m doing a forged crank 400 that’ll be going back in my roadrunner. I would think you’d want a little more gear with that short stroke. I’ve got 3.73s. What are your cam specs?Nothing compared to your build, lol. It's a forged crank 400, Eagle rods, JE pistons at 10/1. Tall fill of Hard Block, studded and girdled bottom end. Bullet solid flat tappet cam, mildly worked Edelbrock heads, M1 intake wiith a dual needle and seat blow through carb, S475 Borg Warner single turbo, MSD programmable timing. E85 for fuel.
Car is a crew cab (4 door) 67 BelvedereGood 727, PTC converter built for the combo, CalTracs, spooled 8-3/4 rear with 3.23 gears, Viking DA shocks front and rear. Car weighs 3,400 and change.
Which exhaust housing, 1.32?240* @ .050" lift, .540" valve lift, 114 CL. I've got a selection of gears, but being primarily a driver, I erred on the tall side. Maybe too tall lol. It had zero traction last year with 275 radials up to at least 60 Mph, so I couldn't really tell.
