Nacho-RT74
- 12:39 AM
- Oct 8, 2012
- Valencia, España
THIS is gold.
Wow, all this time and worry and it's that easy...
That's what I'll do.
I really can't thank you enough.
And that's 12 ga?
Man Thank You ALL again!
That's what I have ilustrated on my diagrams at the dc.com link... just that I made some mods along the time thinking on better ideas while I was learning.
stock are 12. Bypassing the bulkhead paths 10 gauge is pretty much enough but I think he used 8. As I ilustrated on later diagrams at my dc.com threads, I'll be keeping the bulkhead alt path still in use when reassembling my Charger so will keep 10 working with the existant 12. With a better output capacity alt, the batt side barelly will get loads. Sure will be energized and some load will be running throught, but the main will be running on alt side.
Is just like using dual pipes to feed water to the source. You can use two 1/2" pipes, or just one 1" pipes to provide about same ammount of water. Sure some resistance it comes on every connection, and here is where the load will run primary by the easier path, but just like water and pipes, when having conections there is not a total restriction to the water. Here is where the ohms law also plays.
