I have the 3" TTI on my 69 Super Bee. The only place it is tight is by the gas tank. I know I didn't pay $1200 for it either. Would I do it again? No, I would stick with 2.5".
Accurate Exhaust.Does anyone make factory looking Plymouth ‘68-‘70 B body tips for the 3” tailpipes? The oval ones.
I have their 2.5" tips on my RR, but you are correct, they don't list a 3" for Plymouth. You will have to give them a call, maybe they just aren't listed on the site.I was looking for the Plymouth oval tips. I only see the Dodge.
Yeah, but they have TTI in scripted on the side. Or did they remove that?TTI Has 3 inch
My Charger 3 inch does not unless it was very small maybe by the clamp area. I would have to look.Yeah, but they have TTI in scripted on the side. Or did they remove that?
They must have removed it. That is the reason I never bought any TTI tips. I remember asking them about it several years ago, and they said there was a lot of guys who didn't like it on there.My Charger 3 inch does not unless it was very small maybe by the clamp area. I would have to look.
That is what I have always read as well. When I did my Super Bee, I contacted TTI and asked if they would sell me 3" pipes from the headers to the mufflers and the go to 2.5" tailpipes. They did finally reluctantly agree to it, but advised against it. Wanted quite an up charge, so I said screw it and went 3 all the way.By the time the exhaust gasses reach your rear axle, it doesn't really make a difference if it's 2.5" tubing over the axle and out the tailpipe. There is a benefit to the first 2-3' of 3" exhaust, while the exhaust gasses are still very hot and expanded, but after that point, I don't see a restriction with 2.5-2.75" tubing. I'm sure someone has done some testing on this by now.
For example - the Hellcat has a 2.75" exhaust system, so do the 6.4/392s. The mufflers apparently even neck down to 2.5" on these cars, which never crossed my mind when I owned a 2015 SRT.
They are also running catalytic converters.By the time the exhaust gasses reach your rear axle, it doesn't really make a difference if it's 2.5" tubing over the axle and out the tailpipe. There is a benefit to the first 2-3' of 3" exhaust, while the exhaust gasses are still very hot and expanded, but after that point, I don't see a restriction with 2.5-2.75" tubing. I'm sure someone has done some testing on this by now. We often forget that velocity is also important, and should be placed on a similar exhaust hierarchy as flow rates.
We often forget that exhaust velocity is also important to take into consideration, and should be placed on a similar 'exhaust hierarchy' as flow rates. Reduction in exhaust size towards the rear end of the car, will maintain the velocity of the exhaust gasses as they cool down. I'm sure someone has done some testing on this by now, or have a more technical explanation to provide.
There are some great engine masters tests on all this stuff
Absolutely, once the 600 HP threshold is reached, it's time for 3" exhaust systems and low-restriction (high-flow) mufflers. After the header collector extension length (essentially), my question is does it really make a difference downsizing from 3" to 2.75-2.5" after the muffler, , over the axle, and to the tailpipes. I don't believe there would be a significant power loss, but would like to see some data on it.
On some combinations there wouldn't be a loss. On others there would. Question is, if your combination is borderline benefiting from 3" to/including the mufflers, what would you gain from going to 2.5" after the mufflers?
Again, 2.75 is probably fine more many/most but where are you going to find that? You would need to reduce 3" to 2.75 then adapt the 2.75 to whatever tips are available. (in the end, you'll spend more on that than 3")
First you would need to reduce it nicely, with a cone reducer, rather than abruptly go from 3" to 2.5".
Wouldn't seem there would be much money to save. If you're already buying tailpipes and tips.
