fmahannah
1963 Dodge Polara Max Wedge Tribute
- 1:42 AM
- Sep 25, 2014
- Dahlonega, North Georgia
Have issues with dual carter 3705s on wedge intake running pig rich. Cam is 509. Following everyones tips here I bumped up initial timing to get vacuum up, changed metering springs, etc etc. Still pig rich at idle and even part throttle.
So today I decided to pull tops and check float levels for the tenth time, but before I did I cranked the motor enough so it should have filled the bowls since I wanted to see what level they had when full.
When I pulled the tops the fuel level had already dropped to where there was just enough fuel to cover the secondary jets? So out of curiosity I manually filled both bowls to where I figured they would be when full and watched the fuel level. In less than ten minutes it was back down to just over the secondary jets. Both sides. This was with main fuel line to card disconnected.
I pulled the bottom and removed all fuel from it and blew it dry with a compressor. I set it on the garage floor with the edges on blocks and the primaries closed. Then I put enough fuel in each bowl to fill about half way and waited. Within a minute it looked like fuel was dripping onto the primary throttle blades from near the mix needles. It did not seem to be coming from the venturis. Within two minutes gas appeared to be running from everywhere under the carb?
Perhaps without the carb sitting on it's base gasket on the intake this is normal? I would not think so since even with a gasket this gas would and is ending up in the intake manifold.
Or could it be that the metering rods are not in place (but with engine shut off they would not be down and closing the jet passage).
I think these carbs might have major issues internally and need replaced, but if anyone has any ideas on what would cause almost all the fuel in the bowls to run out the bottom of the base plate with the carb out of the car please let me know what to look for. Until I figure out why fuel just runs through the carb when sitting I don't think any amount of tweaking will stp my rich running condition. I can post pics of anything you might want to see.
I'd hate to give up the carters and put eddys on it but don't want to wait for a full rebuild of the carters (if they can be) to be able to get to some shows
Forrest
Forrest
