As shown in the link I provided, but you won't want to buy a can at $225 a pint! Good gasket maker or RTV will work if you let it cure.What did you use for sealant?
Nope, but not something you really want to do after you've just done every other seal and a new pan gasket only to find the pivot shaft was the main culprit. I certainly wasn't tearing mine apart again with nothing else now leaking.Its not that hard of a job.
Some shafts have two grooves for the O-rings.I'm putting my 727 together right now, and have been reading that this pin is a problem always!
I took the pin and machined another O-ring groove next to the original one and bought two Nitrile
O-rings for it. Then cleaned everything squeeky clean with brake cleaner and put a dab of Ultra black
over the top of the pin as shown earlier. Alot of B.S to go through, but I HATE leaks!
Ma Mopar still only put one O-ring on though. The O-ring just gets hard with age, causing the leak. One fresh O-ring has never failed me in 50 years of building TFs.Some shafts have two grooves for the O-rings.
