- 12:15 AM
- Jan 29, 2018
- Midland Ontario, Canada
Measure three times... cut once! I know "foff Wayne"!
My Dad used to say measure 25 times.Measure three times... cut once! I know "foff Wayne"!![]()
It may have been placed wrong. I just got a carpet kit from Stock Interiors, but have not put it in the car yet. Hopefully I can get the paint finished and then try it.That's what I did, but there's no way it will line up with the factory holes in the floor. The carpet is tight into the 4-speed hump. It looks like the heel pad has to go 1" to the right & 2 1/2" up towards the firewall.
Oh man, you're going to lose points at a parking lot car show!!After cutting out the heel pad to match the factory carpet, this is where the gas pedal lands in the factory holes…..
ACC can't find my shipping order & I'm waiting for an email from them so I can send a picture of the shipping label.![]()
Just curious why do you need to cut a hole for the gas pedal? This one down below sits on top of the heel pad.You can see the bottom of the white foam gasket accelerator pedal gasket in the picture.
A 4-door 'Cuda.... hmmmmmm.....interesting 'concept' ....I wonder what that would look like?Could they have sent you a different model like a four-door carpet kit?
I was thinking more like a 4-door ‘Cuda hatchback with a 440 hemi.A 4-door 'Cuda.... hmmmmmm.....interesting 'concept' ....I wonder what that would look like?![]()
Here is a jan 7 2018 ACC thru rockauto carpet. It looks right and has the extra on the edges, was fresh and had zero tough to get out folds, the jute was out of place but that is minor.Here's where the gas pedal is placed on the factory B-body carpets....
However, when I lay the ACC carpet in place, the heel pad will be in this location.....
Look at the bottom of an accelerator petal and it will make perfect sense.Just curious why do you need to cut a hole for the gas pedal? This one down below sits on top of the heel pad.
