1 Wild R/T
The second line your seeing probably goes to the ABS unit... They bleed off pressure to release the brakes... Some early Fords had two lines to the calipers & thats how they were done....
Bubble flare or DIN/ISO flare
Perhaps, but if that's the case - how does the right front get fed then?The second line your seeing probably goes to the ABS unit... They bleed off pressure to release the brakes... Some early Fords had two lines to the calipers & thats how they were done....
Oh yeah, I'm gonna wear out the town looking to match stuff up for sure.NAPA will likely have pre-made lines with ISO flare ends... Plus adapter fittings to work with assorted size fitting on the truck...
Thank you. Yes, that thought has not left me since it happened - it could have beenThe main thing is you’re alright! We’ve all looked at things (whether it’s automotive or numerous other situations)where we say or think, WTF! Glad you used ye old jack stand too!
I very much appreciate that.Glad you are ok Ed.
X2, new brake line front to back! I did a compression fitting once, as an emergency repair and got lazy about replacing it all. It lasted for years till I just could take it anymore, a time bomb that fortunately never went off.I thought it was going to be "I didn't bother to use jack stands" again thread.
You said hole in the brake hose. Looks like the steel line? Anyway the material being use for the last ten plus years is garbage, no matter what part we're talking about. The whole brake line for your truck is available from front to back. I'm not too keen on the compression fittings but I've seen them being used. Myself I'll go with a double flare with the correct fittings. They sell the individual sections of lines as long as you can get to both ends. This is what happens when you find someone has used a compression fitting as one end wasn't easy to get to.
Glad you escaped any tragedy, physical or personal property damage. That's the brakes!
Yeah, it's about brake time for the old guy as it is (I always do new rotors and pads, using factory stuff).X2, new brake line front to back! I did a compression fitting once, as an emergency repair and got lazy about replacing it all. It lasted for years till I just could take it anymore, a time bomb that fortunately never went off.
Planned obsolesence.... Do you think anything in this world is designed to last 20 years? I know NONE of our home appliances are...Glad you are ok. I have a 2003 silverado that had the brakes go out completely twice. The lines rusted through in so many places that I ended up putting all new lines, hoses and new master cylinder on it. Now I have a $2000 truck with $1500 brakes. I bought all stainless and dont agree how the factory saved enough to not put stainless on it to start with.
True, but damn....brake lines??Planned obsolesence.... Do you think anything in this world is designed to last 20 years? I know NONE of our home appliances are...
If you save 10 bucks times a few hundred thousand vehicles, money in their pocket. They don't want it to last forever either.Good Lord - why do makers insist on using crap parts anymore?
Sort of reminds me of reports I've read over the years of corporations (and yes, sometimes even governments)If you save 10 bucks times a few hundred thousand vehicles, money in their pocket. They don't want it to last forever either.
Thanks, brother. A thrill ride I'd just as soon have passed on.WOW Ed thanks for sharing...I'll be checking my '04 Ram today!
Glad you stayed shiny side up!
Funny you telling that story.....Ed mini-story time!I know it's a Mopar site, but about every truck GM made in the early 2000s have had ALL their brake lines, transmission and fuel lines rust off.
Talk about sucky cheap *** materials.
Went to look at a used 2006 3/4 ton Chevy a couple of years ago, clean, low mileage but showing some rust under it. It was at a dealer and the sales guy was kinda a pain in the ***. Started it up sitting in their lot and without showing it basically tried to leg press the brake pedal through the floor.....yup...pop and it went to the floor. Brake line running along the driver's side frame rail. Made the an offer for the truck if they changed all the brake lines...nope.
What DOT were they on in 2004, anyways?
