Ok, I will attempt again. Maybe if I stare at it hard enough it will comply. Thanks for your help.
Dont forget to shake yer fist at it. And couple of swear words wouldn't hurt either. lol good luck.
Quick update. I have the three inch coupler. It is too short. I ordered the 3.5 from Detroit Muscle Technologies. When I bought the manual floor shift column the 3.5 inch coupler was installed. My guess is the 3.5 coupler is used on newer b bodies 73, 74? Thanks for your help.Dont forget to shake yer fist at it. And couple of swear words wouldn't hurt either. lol good luck.
Also if you don't have a service manual, you can download it for free here.
https://www.manualslib.com/manual/1704614/Dodge-Coronet-1967.html
I just installed one yesterday. After 2 previous failed attempts to install on an already installed steering column under hood the past few weekends I finally figured it out. Here are the key points:I know this is an old post, but do you have any idea how to install this clamp? I have a big block which makes it a little tight in the engine bay. I have tried, but I wind up being perplexed at this.
Sorry to resurrect an old post, but I have a question directly related to this. My '64 Fury Wagon with power steering has excess play in the wheel, which I have isolated to the steering coupler which exactly matches the one in this photo. After disassembling I discovered that the shoes were installed 90 degrees off, which accounts for the excess play. My question is how to orient the spring clip upon reassembly. If oriented as shown in this photo, the top of the clip is higher than the inside of the coupler body and would need to be compressed for insertion and it would create significant metal-to-metal contact during operation. Is that correct or should the spring clip be installed differently, or do I have the wrong clip?This one is a little different looking because its a 1962 but the shoes and clip are the same.
Look closely at the pointed ridge on the shoe. You probably have them front to back instead of side to side.
The clip goes under the shoes to hold them outward
Thanks for any suggestions.
-Jeff
Here's my spring mounted to the shoes:
I'm guessing we would consider this one pointed. Any idea how I could find a flat spring, since the rebuild kits seem to be non-existent?
I sure appreciate your help.
-Jeff
Thanks. Mine is indeed a solid pin but only a light friction fit into the steering shaft hole rather than a press fit.Well spotted about the pin khryslerkid.
For sure a roll pin could shear - needs to be solid.
