Cam shaft Numbers help.
unclepunchy
10:06 PM
Victoria, BC Canada
Hi there, I am trying to identify what these numbers mean on these two cams. I figured out its a Comp Cam roller but don't know how to determine the lifts, etc?
#1.
#2.
Well that doesn't seem so easy...
I did a little checking but can't correlate the sharpie writing with that cam?
It could be a custom?
Ya, thats what I am thinking. I just dont know how to correctly decipher what the writing translates to in cam specs.
You need access to the comp lobe master chart.
I would speculate a custom as well, to which I've had comp say
Uh, sorry duuude, we don't know anything...
Thanks guys. Mint tech dept you got there.
Put a caliper on the long and short of the lobe, to get a lift number.
Lobe - base circle, x 1.5 or 1.6
All the Comp cam lobe #s I have are 4 digit, not 3. CC could mean Crane Cams.
Actually, 323-5 and 329-5 are Comp lobes using the older designation.
The first cam matches the specs written on the box.
Actually, it appears that both cams are the same grind.
323/329 - @.020
287/292 - @.050
108 - lsa
.460/.440 lobe lift
