Geoff 2
Dave,
Great to see the Poly. The most underrated engine to come out of Detroit...
- these were low compression engines, 9:1.
- adding an intake that has larger runner CSA will kill off the low end. I suspect this could be some of the problem.
- if the carb spacer you added is an open one, that will also kill off the low end. A spacer for this combo needs to be fully divided.
- the best place for Holleys [ & clones ] is to leave them in the box they come in.
- use a carb that has small primaries such as an Edel 500; you could also use the 800 TQ. They were used here on Ford 302s.
