Huicho417
- 12:45 AM
- Sep 15, 2020
- San Antonio , Texas
My odometer was not turning and I finally decided to remove gauge cluster to take a look. There are two worm drives that operate the odometer numbers, the one that is driven by the speedometer cable seems to have some teeth damaged. Would this cause the speedometer to bounce at low speeds. I tried cleaning everything and even inserted the speedometer cable while i had it out. I did see the numbers rolling over when i did it by hand. However now that its back in the car it seems like the odometer numbers are turning too slow. Does anyone know where i can source the two plastic worm drives?
