Runner72
So I'm getting closer to pulling the top end of my 400 motor apart to replace my gaskets and bolts. I have an exhaust leak at the header, an oil leak at the valve cover, and a coolant leak at the head so I'm pulling it apart to fix all of this. Along with it, replacing plugs and wires, new belts, etc. Right now, from what I assume, it has a stock bottom end and heads with headers and exhaust, torker 383 intake, and a Holley 750 carb. Since I'm going to be pulling everything apart, is it worth it to go ahead and upgrade the cam(assuming it's stock- I'll check when I get it apart)? I want to do a 4 speed swap and looks like a kit from Passon runs at least 5-6k and will be a little while before I can swing that and part of me feels like I'll regret not doing the cam now, which seems like $500-$1000 depending on the cam and I'm assuming new lifters and springs. Any thoughts?
