Roller cam lube
furyus
3:08 AM
weeki wachee, florida
So, I saw David Frieburger coating his roller cam with what looks like white grease. Opinions? If it's good to do, then I will do it. I thought regular oil was what you used, but on an engine that sits in the building process, that oil will run off.
Tell me what you think.
My thoughts regarding any grease is that it will clog small passages, the filter, etc.. I'd use assembly lube instead - its thick enough to stick to parts and will dissolve with the oil. But the oil still needs to be changed after a short run in. So with all that said, with a roller cam ... I wouldn't bother with any of that crap, I'd just prime the motor while spinning it by hand then fire it and drive it.
White grease for checking gear pattern drys a bit so if it's the same as DF used, I wouldn't do it. Roller cams don't need to be broke in like a flat tappet does so like Stanton says, that would be better imo. I used to mix STP with oil for my builds and never had a problem with that. Priming the engine is pretty important....
With my roller cams, I'd soak the lifters in the 20/50 oil for about a day, then with the cam I'd just wipe a bit of cam break in on the lobes. I know the rollers don't need it, but can't hurt.
This.
Take a dab of that between your fingers and see how it feels then do the same thing with the other hand with STP and see if there's a difference. Years ago I tried that with some assembly lube but don't remember the name of it. Couldn't feel a difference but the price sure is different....
Good too know.
I remember my dad telling me that’s what he used (STP) in the 70s when he did his engine building.
Lubriplate does make an assembly lube that is white but, I kinda like the tubed assembly lube with moly in it, a dark/black lubricant with very high friction load capability. I can't remember the brand and I'm not going out to the shop to look.
Use a liquid lubricant, oil or the stuff in post #8....which looks similar to the lube that Comp Cams supplies with new cams.
I used a Crane lube for many years, both SFT and roller. The Comp lube looks and feels the same. Even on a roller, it doesn't hurt.
