MSD Rev Control
HardCharge
7:23 PM
Kentucky
I found a MSD Rev Control #8738 at a friends house that he's never going to use. He gave it to me, if I can use it. I have a 1967 Charger but it has a 360 now with electronic ignition. Is there a way that I can wire this in. The tech line at Holley was zero help. The rev control is probably 20-25 years old. But still new. I'd like to use it if possible. Has anyone wired one into a stock ignition setup?
I know there is a plug issue. But I can make my own plug. Does anyone know what wire runs where? ex. red to coil, black to altenator ect.
That is called the Soft Touch - I ran one for a long time in my GTX. Works well, and easy to install with all stock components kept in position.
Download the PDF "8728" and look at Figure 9.
  • Soft Touch 5478738.pdf
  • Soft touch 8728.pdf
Thanks Kiwi......awesome help. :thumbsup:
Mine is an 8738. The installation instructions are different between the 28 and the 38. Did you run a 38 or a 28? The 38 states that It must be used with a 6AL ect ect ignition.
The wiring colour code should be the same.
