It’s hard to tell what’s going on here, but these are a couple of pics of the driver’s side of the trans, fully installed. The passenger side seemed to have better clearance than the driver’s side. No cutting necessary.
Yeah, I hate that tractor gear tooIt is a nice transmission and is much smaller than the older Tremecs, but for a B body Mopar, you still need to cut up your transmission tunnel to make it work. I spoke with a Tremec guy at Carlisle who confirmed this.
Yes, the Passon A-855 took me 5 years of waiting to get (prior to that I used a cast iron A-833 with OD gears and the shitty 3.09 1st gear). But, once I got it, it dropped in place using all my stock parts, with the shifter in the stock location. I love it - it works beautifully.
I realize I used the wrong phrase by saying "cut up the transmission tunnel". As you stated, the shifter cannot be in the stock location so you need to cut a hole in the transmission tunnel for it. Obviously, on a manual car, the original shifter hole needs to be covered up as well.The only hole I had to cut was for the shifter. I had to remove a couple of screws from the rubber boot for the A-904 shifter rod for clearance, but I did not have to cut anything to clear the transmission housing.
what did it end up costing if you dont mind me asking? Do you whale on your car every now and then? whats the rpm in 5th on highway?It is a nice transmission and is much smaller than the older Tremecs, but for a B body Mopar, you still need to cut up your transmission tunnel to make it work. I spoke with a Tremec guy at Carlisle who confirmed this.
price?how long on the wait and how much cutting on the floor? Used stock parts?I know there’s people that can’t afford to spend $7k plus on a tranny swap but then there is those that can’t afford it but can afford their bad habits and so forth. So I made my car my bad habit instead. I was one of the first ones on Jamie’s list for the 855 but after getting skipped over several times I said to hell with it and made the decision to put a Close Ratio T-56 Magnum in it. I didn’t care what cutting it took to get it in the car and after I drove it I’ve never been happier with my decision. With a gear ratio of 2.66, 1.78, 1.30, 1:1, .80, .63 it’s the best standard transmission I’ve ever driven.
I bought the T-56 in 17. I got it right away of course back then. I bought a complete kit that included a hydraulic clutch and everything. I paid $7k for it back then but the clutch they gave me was junk. I’ve since went to a McLeod that I haven’t installed it. We cut a pretty good little chunk out of the floor and made our own hump. Not perfect but it turned out pretty good back then.price?how long on the wait and how much cutting on the floor? Used stock parts?
1 thing to be careful about installing a TreMac in a Mopar besides the transmission width is its length of the tailshaft.. Often this requires the engine to be pushed down slightly which tends to not allow an air grabber base to set flush with the hood scoop gasket..what did it end up costing if you dont mind me asking? Do you whale on your car every now and then? whats the rpm in 5th on highway?
I bought an 18 spline clutch as well since my other A-833 was a 23 spline. With a complete clutch and the tranny, plus a new transmission yoke that slips in to the transmission (mine was pretty shot), I was right around $6000.what did it end up costing if you dont mind me asking? Do you whale on your car every now and then? whats the rpm in 5th on highway?
If they ever go out of business would you be able to get parts?they need to make it so you can use the Mopar bell housing. From what I see I would have to replace my drive shaft and new bell housing on top of the cost of the Tremac. Might as well; get Jamie Passion Performance with the 855 Passon Performance A-855 Five Speed Transmission
You have to change all that if you go from a automatic to a manual. My passion that’s on order is going into an automatic car that I’ll have to do a lot more cutting to the trans tunnel not so if I went with a Tremec TKX.But when installing a Tremac TKX U need to change bell housing, clutch linkage... The Passon OD drop right in without any mods.. So in the long run the Passon OD is less expensive..
Just my $0.02...
I know, I’ve been waiting on a Passion for a while now, I’m 23, I probably won’t see it until I’m 30. Imagine waiting for a part. Where a Tremec TKX you can get the part within three days if needed.If they ever go out of business would you be able to get parts?
Will it do this for a real 4 speed car? I wasn't aware there was any Tremec transmission swap that allowed for a stock location of the shifter.The American Powertrain kit will put the stick in the stock location for the 4-speed shifter.
5 years is a long wait. I guess I should get my order in now. Did you have to pay for it first and then wait 5 years, or do you pay for it when its ready?It is a nice transmission and is much smaller than the older Tremecs, but for a B body Mopar, you still need to cut up your transmission tunnel to make it work. I spoke with a Tremec guy at Carlisle who confirmed this.
