Max Wedge INtake Torque Settings
fmahannah
1963 Dodge Polara Max Wedge Tribute
3:31 AM
Dahlonega, North Georgia
Is the correct torque for max wedge intake manifold bolts 25 ft lbs? This is with iron heads.
I used to do 20 to 22
Too expensive an intake to risk cracking!!
It always sealed if surfaces were flat and clean
I would do no more than 25 lbs on mine. Pretty standard for an aluminum intake. I might try twenty......
(How good are the threads in the max heads? Got a couple helicoils in mine.....)
The old specs were 25 or 30 depending on where you looked...I would do no more than 25 if everything fits perfect, less if it does not, or fix the bad fit.
Agree, 25. You are sealing something, not a structural component. Edel recommends 25 for it's intakes.
Chrysler "Wedge" (B & RB Series) Torque Specs​
The following specs apply to these Chrysler Big Block engines:
  • B Series,
    • 350 c.i.d.
    • 361 c.i.d.
    • 383 c.i.d.
    • 400 c.i.d.
  • RB Series,
    • 383 c.i.d.
    • 413 c.i.d.
    • 426 Wedge
    • 440 c.i.d.
Fastner Type​
Torque Specs​
Main Cap Bolts
85 ft.-lbs.​
Connecting Rod Bolts (Plain)
45 ft.-lbs.​
Connecting Rod Bolts (Heavy Duty)
50-55 ft.-lbs.​
Crankshaft Rear Bearing Seal Retainer Bolts
30 ft.-lbs.​
Cylinder Head Bolts
70 ft.-lbs.*​
Rocker Shaft Bracket Bolts
25 ft.-lbs.​
Intake Manifold Bolts
40 ft.-lbs.​
Oil Pump Cover Bolt
10 ft.-lbs.​
Oil Pump Attaching Bolt
35 ft.-lbs.​
Oil Pan Bolts
15 ft.-lbs.​
Cam Locking Bolt
35 ft.-lbs.​
Harmonic Damper Bolt
135 ft.-lbs.​
Flywheel/Flexplate Bolts
55 ft.-lbs.​
Flywheel Housing to Engine Block Bolts
50 ft.-lbs.​
Flexplate to Torque Converter Bolts
270 in.-lbs.​
Water Pump Bolts
30 ft-lbs.​
Fuel Pump Bolt
30 ft.-lbs.​
Starter Mounting Bolts
50 ft.-lbs.​
Exhaust Manifold Nuts
30 ft.-lbs.​
Do not try 40 with a 426 hemi unless you like to EZ out every hole in Head.
I do 40 on a cast intake but not aluminum.
Just my opinion
Once the engine has run & cooled down, I would torque again, cold. Keep repeating until you cannot tighten further.
Is there a service manual entry for the Maxwedge. The hemi aluminum was 72in/lbsf but they are 1/4" bolts/studs
