- 5:48 AM
- Sep 25, 2014
- Dahlonega, North Georgia
Is the correct torque for max wedge intake manifold bolts 25 ft lbs? This is with iron heads.
Fastner Type | Torque Specs |
Main Cap Bolts | 85 ft.-lbs. |
Connecting Rod Bolts (Plain) | 45 ft.-lbs. |
Connecting Rod Bolts (Heavy Duty) | 50-55 ft.-lbs. |
Crankshaft Rear Bearing Seal Retainer Bolts | 30 ft.-lbs. |
Cylinder Head Bolts | 70 ft.-lbs.* |
Rocker Shaft Bracket Bolts | 25 ft.-lbs. |
Intake Manifold Bolts | 40 ft.-lbs. |
Oil Pump Cover Bolt | 10 ft.-lbs. |
Oil Pump Attaching Bolt | 35 ft.-lbs. |
Oil Pan Bolts | 15 ft.-lbs. |
Cam Locking Bolt | 35 ft.-lbs. |
Harmonic Damper Bolt | 135 ft.-lbs. |
Flywheel/Flexplate Bolts | 55 ft.-lbs. |
Flywheel Housing to Engine Block Bolts | 50 ft.-lbs. |
Flexplate to Torque Converter Bolts | 270 in.-lbs. |
Water Pump Bolts | 30 ft-lbs. |
Fuel Pump Bolt | 30 ft.-lbs. |
Starter Mounting Bolts | 50 ft.-lbs. |
Exhaust Manifold Nuts | 30 ft.-lbs. |
Ok thanksOnce the engine has run & cooled down, I would torque again, cold. Keep repeating until you cannot tighten further.
