The PCV goes in the valve cover and the hose from it goes to the capped vacuum port on the carb. download or print off a manual for your car here.So put a pvc in to the carb?
mymopar.com
Yes I have checked the wires,cap, and rotor all good.Yes run a PCV valve for sure.
Also as mentioned it could be the accelerator pump is not giving you that extra shot of gas when you stab it.
Could be one of the plug wires is arcing on something. Have you checked the plugs, rotor and cap for any carbon buildup ?
Honestly there are a ton of reasons you could be having rough running.
I have replaced gas tank, fuel filter, and fuel pump. But I will check the pressure. I’ve noticed that my fuel filter is not staying full, it drains down so I’m thinking I have carb issues. I ordered a rebuild kit for the edelbrock 750. Gonna try to do it myself it will be a first for me.all of the above, choke could be not opening completely you can check that with the air cleaner off while running. accelerator pump may not be working, or float height too low. put a pressure gauge on the fuel line. a plastic inline one 0-10psi from mr gasket is fine. edelbrock AVS needs a certain amount of pressure. if it's really low pressure then suspect fuel filter or fuel pump/pushrod.
I would definitely not go to EFI at this point in your ownership as you will just be adding complexity, stick with a carburetor. clean this one up or buy a 650cfm AVS2.
I’m not sure how or which way to adjust the kickdown. Is there a website I can get some instructions on it? Or can you instruct me on how to?Like Don and I suggested, if there is no simultaneous travel of the kickdown arm in relation to the throttle, there will be the potential for a lot of slippage of the front clutch in 3rd gear under a load if there isn't a proportionate amount of clamping force.
You need to do what I said in post # 19!!!!!!!!! It's a job that's better to be read than explained!!!!!!!!I’m not sure how or which way to adjust the kickdown. Is there a website I can get some instructions on it? Or can you instruct me on how to?
You need to get an FSM and stop asking so many questions! You do know what an FSM is don't you?
Watch this it should help you adjust the kickdown.I’m not sure how or which way to adjust the kickdown. Is there a website I can get some instructions on it? Or can you instruct me on how to?
No, the PCV valve goes in one valve cover and the vacuum line from it runs to the vacuum port on the carb that you have capped. The vented cap on the other valve cover is the intake and the air is pulled from the intake side, through the crankcase and PCV valve via the suction line at the carb base. Your setup shows 2 vents, but no suction, thus no "positive" air flow through the crankcase.So put a pvc in to the carb?
Very helpful thank you reading is not my specialty I’m more hands on and video thank youYou need to do what I said in post # 19!!!!!!!!! It's a job that's better to be read than explained!!!!!!!!
Appreciate the help gonna do that after workNo, the PCV valve goes in one valve cover and the vacuum line from it runs to the vacuum port on the carb that you have capped. The vented cap on the other valve cover is the intake and the air is pulled from the intake side, through the crankcase and PCV valve via the suction line at the carb base. Your setup shows 2 vents, but no suction, thus no "positive" air flow through the crankcase.
To lazy to read and get the truth instead of some moron on Boob tube trying to explain it!Very helpful thank you reading is not my specialty I’m more hands on and video thank you
Like I said before if ya just wanna be rude and a *** don’t comment. I asked for help not moron responses 69a100To lazy to read and get the truth instead of some moron on Boob tube trying to explain it!
You have to put @69a100 for him to see it.Like I said before if ya just wanna be rude and a *** don’t comment. I asked for help not moron responses 69a100
Having the PCV system set up properly is good for your engine, but I think we got off on a tangent and I doubt that is contributing to your original problem.Appreciate the help gonna do that after work
