Just to kick this around. I have a 489 rear end and have the open 741 pig in the car now. Will my axles work with the 489 or are the splines different? Thanks for the help.
Yes, the cone style also has a bolt together diff. The Powr Lock in the Dana looks just like the one in the early 8 3/4's but yes, MUCH larger. The Track Loc came many years later. Not sure when they came out but never found one in a 60 that was for cars of the 60's/early 70's.Cranky, you have really confused me now. The rears I have had, '66 ish 742 had the bolt together clutch style, the 489 was a cone style, each of the Dana 60's had the bolt together clutch style, MUCH larger than the 8 3/4 style. I have no experience with later model stuff.
8 3/4 axles splines are all the same.Just to kick this around. I have a 489 rear end and have the open 741 pig in the car now. Will my axles work with the 489 or are the splines different? Thanks for the help.
Other than an aftermarket 35 spline spool, ALL 8 3/4s axles are 30 spline.Just to kick this around. I have a 489 rear end and have the open 741 pig in the car now. Will my axles work with the 489 or are the splines different? Thanks for the help.
Not sure what has been said on later suregrips, but the cone system is poor at best.
I have rebuilt them but with the introduction of ‘true trac’ Gear drive diffs, I would not bother now.
Just stump up for the ‘true trac’ and put your troubles behind you.
HNY from Limey John
PriceHi CH340,
I have had 68 and 69 R/T's, both with original Mopar 'dana' clutch units!
As you probably know they are date coded on the dana units and I have never seen a 69 one yet?
But it could quite easily get into a 69 car depending on factory and build date...
They have their problems as well as the later Auburn cones!
I personally would go true-trac now!
Gear drives have no resistance in normal driving and full locker under load...
Haven't heard anyone braking them (as yet) but I have broken many 'Chinese' lockers (cone and clutch) lol
What's not to like lol...
Hi CH340,
My pleasure CH340.
I can afford a diff but not GAS!
Once you’ve broken a few Chinese lockers and the grief you get from Folks, I will never go back...
Original true trac’s Were made in the USofA but now I’ve seen Indonesia?
We (I helped a buddy run his car) started breaking 8 3/4's when the car got into the low 11's but the car was also running a 4 speed and launching at 6k. After breaking 3 (shaved teeth) the car got a Dana 60 and more power and got into the mid/high 10's.Love 8 3/4 rear ends. Back in the day my 68 coronet ran low 11s with an 3.91 8 3/4 rear and never had any problems.
This guy's car was consistent as the best ones with automatics! He could shift and had the right clutch and shifter for consistency. I was good too to the point where some didn't believe I had stick in my car. They had to go look inside. Had several at the track come up to my buddies car in the pits and ask us where we got the 4 speed automatic. We would just point to the car and said 'go look' lol68 beast was an automatic, consistency was everything
I like being reminded of this. I will always row my own! THAT is a big part of the enjoyment I get driving and racing my Roadrunner.I was good too to the point where some didn't believe I had stick in my car.
I finally found an 833 last month that's newly rebuilt and did a trade to get it! It's not a Hemi box but my engine is a basic mild build and my car is light so I'm not worried about hurting it....unless I've lost my touch and grind the gears out of it lol but the last time to give it a shot, I still had itI like being reminded of this. I will always row my own! THAT is a big part of the enjoyment I get driving and racing my Roadrunner.
