Post your 11 second combos
My final outing of 2021 gave me a little improvement. Still the same 10:1 451” I started the season with. Still more on the table.
Nice! Just getting out and having some fun is very cool. Looks like you’ve got a Mid-11 second car right now. Mine went 12.40‘s the first time out. Just whittle away at it. with The parts you’re working with, I’m sure you’ve got 6-second / 10-second time slips in your future.
The last pass I tried leaning on it a little higher rpm and finally opened the cut outs. And it felt better then I had a bone head mistake and shifted from 1st to 3rd
My old 440 combo:
63 Plymouth Sport Fury weighs 3700 with driver.
.030 over 440 with stock crank and rods
KB quench pistons at 10.0 comp and .045 quench
906 heads I ported and added 2.14 & 1.81 valves
MP .557 cam and Isky ductile iron rockers.
Holley Street Dominator intake with an 850 DP carb
Mallory dist and MP orange box
1-3/4 hedman headers and 3" pipes
727 with T/A manual v/b and Dynamic 9.5 converter
4.30's with 30 x 9 Hoosier radial slicks
SS springs and 90/10 front shocks.all other suspension stock
Best et: 11.49 @ 116 , Ron
That was almost identical to my old combo in my 63. 440 stock bottom end 590 cam worked heads w / roller. 3000 stall with 4.30s best 11.70
.030 over 440, KB hyper flat tops, LY rods, factory steel crank, ported edelbrock RPM’s, comp xtreem roller 254/260 on 110, .620/.624, ported M1, 1050 dominator, 4.10 gear with loose 10” vert. Car is 3660 without driver. Just a street car, battery is even still up front. Time slip is left lane. Car has been a best so far of 11.27. Car is my buddies, I built the short block about 20 years ago.
Nice. What was the DA?
What kind of tires are you running on the back of that thing to get you 1.68 60ft times. Do they come with special glue to put down on the track? :lol:
