Joel Talka
Hi All;
I did get my 1966 833 rebuilt and all put back together, but I think I have a problem and am looking for some advice.
Actually shifting.. I installed the old shifter set up. The tranny will shift 3rd and 4th with no problem but shifting into 1st or into 2nd is really hard and takes a bit of coaxing..for some reason that 1-2 slider does not want to slide...
If I remove the cover, I can move the 3-4 slider easily by hand. The 1-2 slider will not move, I need to pry it while turning the input shaft to get it to engage either gear... not an easy process. This can't be normal..
I'm enclosing some pictures. When I did the overhaul, it was the two 307 bearings, new needle rollers, new synchros and seals and gaskets.. nothing else was changed. The cases were glass beaded and flushed with brake cleaner. I've oiled everything inside the case..
Any thoughts?
Joel
Any thoughts?
Joel
