Big Bad Dad
- 10:07 PM
- Jun 11, 2011
- Fincastle, Va.
After years of red grease turning to liquid and leaking out of the gun in my tool box, I switched to Lucas Xtra Heavy Duty "green" grease. Good stuff, and good online reviews. So I have been using it for a couple of years, including the wheel bearings in my car trailer and the wheel bearings and front suspension, etc. in my vehicles. I do not want to mix different greases in wheel bearings, as that can cause problems if the greases are not compatible. NOW, I can't get the Lucas green grease any more. Seems they had a plant fire and/or supply chain issues. I need to know what grease is compatible, and will work with the Lucas. I tried contacting Lucas thru their website, and did not get a response. I need to find another grease to use in my trailer wheel bearings now. I guess I will need to clean and repack the ones with Lucas in them when the time comes.... Anyway, what wheel bearing grease have you guys found to be the best, and that doesn't turn to liquid when left in the tool box?
