Watch out for Ford wheels. They had the same bolt pattern, but the center hole is slightly smaller than the Mopar hub. It will cause the wheel to not seat properly and the lugs will loosen. I learned this the hard way many years ago. Almost lost a wheel on my 65 Coronet....thanks Mcodecuda. Would be nice if there was a Pentastar stamped on there somewhere!!
If you find any that are SURPRISINGLY heavy, then they are probably Dodge/Plymouth cop car wheels.Any easy way to ID 15x6 or 7” steel wheels? I found a junkyard with stacks of rims but not sure how to tell them apart. Thanks in advance
