Tony 69
Hi members. I’m sure describing a noise on a post isn’t going to go to well but I will try anyway. I have a whomp whomp noise between 60-80. It doesn’t change “that much” whether on/off the throttle. But it gets loud and very rhythmic. Almost sounds like something is going to break. There is no vibration, just whomp whomp whomp. As far as I can tell everything is tight. New u joints and a yoke too that was worn out. No tail shaft seal leaking. Can my engine cause this? I have an oe balancer but don’t know about the internals of the engine. I see some 440 were externally balanced and some not.
Should I try a fluidamper balancer. It’s an expensive guess. Unfortunately the noise kinda fills the car so I’m not sure where it’s coming from. Thanks for your suggestions.
