$175 for a filter lmao!!!!!
My 62 had one. Still had the 2 hole pan filter.
It's $195!
This one is $267!
External ATF filter for 1960-63 Plymouth - Dodge - DeSoto - Chrysler - Imperial with TorqueFlite
If all the later model TFs didn't need the inline filter why would the 62s? I'm thinking engineering was overruled by the bean counters for 63 and later.
Every filter that Transgo ships in their shift kits is a brass screen. I recall B&M did so too. Can't be too bad.They only had an internal screen not a dacron fabric filter.
Thought that I would give an update. After removing the pan, I found that there was a factory two hole filter. I put in a new one, cleaned the pan and painted the outside, New gasket and good to go. I also found a WIX 58964 in line transmission filter is very close to the same dimensions as the original MoPar, Downside is that it uses rubber hose connections. I'm not going to cut the original lines, but will make up steel connections.
Not to do anything other than simulate the factory stuff. As I mentioned, this is about the cleanest early B body that I have run across in many years. It does have issues though. Just want to thank y'all sincerely for your help.
John
Dacron.Was the filter a metal screen or was it made out of a fuzzy cloth looking material (Delron)?
Gonna need some photos of this bad boy ! Sounds interesting.this is about the cleanest early B body that I have run across in many years.
Being 80 years old I was in my early years before working for Chrysler and as a tech on a one year service we would change the in-line filter. I always turned them inlet side down but never found any dirt as the flat filter in the pan caught it all. I was on the Chrysler Racing support program and they did away so that the flow was not slowed to allow proper cooling of the fluid.When the "069J" converter was made available to all of the racers on the program we always made sure the in line filter was removed and the deep pan used after we converted them to Chrysler "manual" shift automatics.Recently purchased an original '63 Polara with a poly 318 and 727. Just starting to do some maintenance on it. The transmission filter is a "can" that is inline with the trans line, It is original I've seen them before, but now I own one. I haven't dropped the pan, therefore I hope that someone might tell me if there is a regular pickup in the trans that I can swap to a later in pan filter OR better yet, are replacement in line filters available. I checked Rock Auto and they show a typical in pan filter for a '63 but for '62, there is nothing.
I appreciate any replies.
