Back up light switch operating lever missing- column shift
My only concern with an actual bolt is whether or not the head will clear the switch housing and then would it align/adjust correctly if the head was hitting the switch vs the shaft.
Just jam two nuts on the top and remove them when done.
Got it. Good point.
I decided to punt on this for now. Maybe at a later date I could delve into it some more. For now I installed a simple surface mount SPST switch down near the left hand air vent knob so I can turn on the lights manually when I back up. Thanks for the many suggestions - I will keep them in mind.
Did anyone end up making one of these in a 3d print of an original?
