When I prime, I look for full oil flow out of each side of the rocker arms. Just my way.
Yup ! That’s what I am looking for !When I prime, I look for full oil flow out of each side of the rocker arms. Just my way.
I didn’t remove the cam shaft or bearings. Since they worked fine prior to, my assumption is that their positions have not changed. The only thing that I replaced was the timing chain and sprockets.I do the lazy-mans way and just check that the bearing is installed properly and the feeds aren't obstructed.
If that is the case, looking at the 1-3-5-7 side would show you if it was getting oil or not. A dry side would show heat marks...blue and black metal at a minimum.Yup ! That’s what I am looking for !
