- 1:20 AM
- Jan 15, 2020
- Okeechobee, Florida
But they tried to get it right...
Chuck (snook)
Chuck (snook)
I shoulda went big block BAH...Yep 270 (cc) TrickFlow heads
Chuck (snook)
True that.The joys of doing, and having the balls, to show stuff live! They have it running just fine and showed it live on their Friday night show. This engine belongs to a buddy of my Wife's cousin.
You can click through it pretty quick Ray until they pull the distributor. Some aftermarket electronic conversion on a cast distributor. The shaft is two pieces and it's threaded.. right hand. Of course the distributor turns CCW and the 2pc shaft was threading apart changing the timing every time they started it up.Have a pc of the distributor? Not watching a hour.
It was a cast housing modded with electronics and it had a threaded shaft. The tanged end unscrewed. #1 was all over the cap.Have a pc of the distributor? Not watching a hour.
I am sure it is The MP electronic one I can tell by the advance plate with the built in reluctor. Good distributor, not seeing the screw on shaft. Hard to get internals for them. Not made for years and even then scarce, everything is specific to that Mopar electronics inside it. I get them in usually welded to lock them out for crank triggers!It was a cast housing modded with electronics and it had a threaded shaft. The tanged end unscrewed. #1 was all over the cap.
I am sure it is The MP electronic one I can tell by the advance plate with the built in reluctor. Good distributor, not seeing the screw on shaft. Hard to get internals for them. Not made for years and even then scarce, everything is specific to that Mopar electronics inside it. I get them usually welded to lock them out for crank triggers!
