- 9:02 PM
- Oct 25, 2010
- Monroe, New York
upon removal of my valve covers & inspection of my 440 engine. I found double valve cover gaskets & shims under my rocker arm shafts. Looking for answers to the why?
I found this on web...
Back in the day, rocker shims were used frequently to decrease the stock preload on hydraulic lifters with the stock valve gear. I have an old Motion Performance handbook from the 70's that goes through the procedure for that very reason.
I will set up the shaft, by shimming them to get the narrowest contact patch across the rocker. The narrowest contact patch will result (98%) of time in the greatest amount of valve lift. I have tested a few different methods and the greatest amount of lift/narrowest contact seams to result in the least amount of guide ware. I personally don't care if it's centered or not, as long as it's not more then .060" off center.
Once I get that all established I will get my pushrod length by truning the adjuster out 1 full turn and measure it at that length.
