70chall440
- 12:52 PM
- Feb 11, 2018
- Yelm, Washington
I am more than happy to do so because I want to know as well. I agree that one can put together a working HB system for well under ~$1000 however I will post a roll up of costs at some point. There is a lot of wiggle room in costing because you can use rubber lines over SS braided, get a HB unit from a salvage yard, do your own fabrication, etc.I think this whole process is moving in the right direction and would be doable for well under $1000.00. You have really helped take some of the mystery out of the booster set up. Thank you for your time and effort to post your information here for anyone else who wants to upgrade their brakes.
The one issue that seems to be elusive is that of operating pressure, what I mean is that a stock Mopar box as found in a classic car is designed to operate at 800 or less PSI, however a HB unit typically needs more like 1200 - 1600 psi. So this has to be something that is addressed from the beginning. Like the rest of the issue, this aspect is a bit murky and the next thing I am going to delve into.
