slimt
instead of Bad Chad. Its Bad Dad.with a vision.Where was the film crew??
UMMMM.. the axle flange diameter doesn't fit through the press frame gap and you also have the outer seal/retainer plate in the way so you don't have much to "catch" with the press plates as you don't want to be pressing on the retainer. You can't turn it 90 degrees and press across the two bearing splitter plates as the bearing retainer plate diameter is out past the plate retention studs.FWIW - I've been told to position those bearing splitters with the cast frame spanning the gap in the bucking frame as they are stronger in bending than the bolts.
—-3/4" air intake hole in the back of the cabinet and also the hole the axle was stuffed out through and before I could get it unplugged I sucked the cabinet in and broke the viewing glass! After that I took the complete 3" plug out of the cabinet back for air in.
Before
After a quick blast and ready to do the back side
Axle flanges and bearing areas sprayed down with Boeshield T9 corrosion protection.
I can leave the door open and zero dust in the shop ! LOL—-
Got to love the ingenuity that comes with home projects. Betcha there’s good visibility in that blast cabinet now that there’s make up air in there.
——I can leave the door open and zero dust in the shop ! LOL
1942 - 14 x 42 ForwardThat’s also a pretty beefy old lathe chuck holding that axle. Nice set up.
——1942 - 14 x 42 Forward
—-Left axle bearing being pressed into place.
7 Tons of pressure to seat it into place.
One down, one to go.
Right side is up next.
Right axle bearing pressed into place.
Wrapped in plastic to keep any foreign material out until ready to install into axle housing.
