Huicho417
I have been tracing an oil leak that I thought was coming from the oil pressure sending unit. Located the rear of the block. It has been getting progressively worse over long drives and have come to the conclusion that it is the rear main seal. When I look under the car I can see oil residue in between the transmission and engine. To the point where it starts to coat the transmission pan.
I will be replacing the oil pan gasket, oil pump and rear main seal. Any tips on this procedure as it will be the first time I do this? Does sealant get added to the rear main seal? Any pictures would be great.
Thank you in advance.
