ksurfer2
I have wildwood disc brakes on all four corners of my 64 NSS car. The master cylinder is from a 90's Dakota. This set up worked fine since installed. However, now the fronts are dragging REALLY bad...I can hardly turn the hub by hand with the wheel off. Both sides are equally bad. If I crack a bleeder valve, it squirts out fluid and then both sides will turn freely. Stepping back on the brake pedal will result in the brakes locking up again. I replaced the flex lines on both sides with no change. Fluid flows through both sides freely. There is no proportioning valve. One brake line goes to the rears, the other goes to the line lock and then splits from the line lock to each wheel. It seems to me the problem may be with the line lock since that is all that effects both sides the same. It does function properly, but is there a reason it may not be properly releasing pressure.
