Dip stick hole
Roger63
5:25 AM
Skiatook ok
Has anyone ever seen this? It appears that a metal plug has been inserted into the dipstick hole.
Remove the pan and tap out with a punch. Dodge pickups used them because the dipstick bolted into a fitting in the side of the oil pan.
I have mine tapped with a pipe plug on my block. I run Moroso 4 vane vacuum pump.
I got it out by drilling a small hole half way through and screwing in a sheet metal screw and yanking it out.
Thank y'all
Drilling and screwing a hole, ok, but yanking it out ?
Well of all the things not to be on You Tube...
Back in the 80's there was a spoof I believe it was on SNL, could have been Rick Dees, about those annoying "Your Door is Ajar" Messages... The woman's voice warned that the door was ajar a couple times then proceeded to say "Your Dipstick is Long" To which a man's voice responded "Thank You"....
I was gonna drop it right here but I couldn't find it... Hopefully someone gets a chuckle ut of the typed version...
The thread title reminded me of an old Rugby song......but then I realised this was about cars. :rolleyes:
That's the ultra-rare, Mopar, dip stick delete option!
Hang on to the plug, there's guys out there that need them for their 440 truck install
