matchek
- 12:59 AM
- Feb 13, 2023
- Research Triangle Park, NC
Hi, I am stumped as to what is going on with my cooling system. Today after driving on the highway around 40 minutes from the shop for work that supposedly had nothing to do with the cooling system, the car overheated (temperature to 250F). I had the car two years and have not driven it much. This is longest distance I ever drove it. To clarify, I had work done on the car. Before I picked it up, the mechanic test drove it for around 10 miles and this morning I test drove it for around 5 miles around town. The car was running very well for both us. To get home, I drove around 5 miles on city roads with several stop lights (no overheating - Temp at ~ 185 F), then drove around 30 miles on the highway between 60 and 80 mph (no overheating - Temp ~185F). On around the 35th mile while going around 65 mph on the highway, almost home, the temperature climbed from 185 to 235 F in what seemed around 3 to 5 minutes in a steady clockwise fashion. Luckily I was routinely glancing at the gauges. At that point, when I exited off the ramp and sat at a traffic light, the temperature then went quickly to 250 F where I pulled over and shut the car off. Did not see steam from the engine or the radiator. I did notice a little fluid dripping off the front behind the license plate [ at that time did not notice where exactly it was dripping from]
Extra info: I had the car for 2 years where I typically idle the car in the garage or have taken short 10 miles trips and never experienced any overheating. Did not drive it much because I had brake problems which are now fixed. Today, the car drove great for the first 35 miles and then started overheating at around the 36th mile.
After letting the car cool for 4 hours, I opened the radiator cap and and to my surprise not that much liquid was gone. I added about one quart of 50/50 coolant and topped it off. II remember from reading the manual not to top it off entirely and did not before, but today I did for reference). I started the car and let it run for around 10 to 12 minutes. After around 5 to 8 minutes, some water overflowed out of the radiator overflow hose, and the the temperature was again rock solid at around 185F while idling the car in the driveway and then I shut the car off (185 F and not overheat) The water level remained mostly at the top or close to it while this idling. The oil was not brown and the top radiator hose was warm when running. I did not notice any steam coming from the head gasket, water pump or radiator.
Any ideas as to why car overheating while driving this extended trip at speeds of 60 to 80 mph, but when I idled it in the driveway it was stable at ~ 185 F again? I am glad it running well again in my driveway, but I am afraid to drive it. I ordered a a new thermostat for good measure. Since I got the car the radiator I did not flush the system. It looks like in great condition and the water level is always on the high side so didn't think it was a problem. Thinking perhaps something could be blocking at high speed.
As far as driving he did install a new distributor and adjust the timing. He also removed and reinstalled the transmissions to replace seals (I have to take it back because after I restarted it after the install, the car shifts to neutral after about 15 seconds and the mechanic said it was not tighted well enough after reinstall). I speak to this more in a post later in this thread.
