Skytrooper
1SG (Ret.)
- 12:46 PM
- Oct 26, 2017
- NY Finger Lakes
Good Morning and thanks in advance !
I am horrible at electronics and have decided to move away from points. The instruction sheet that came with the electronic ignition look fairly straight forward, but being an electronic imbecile...I have a few questions.
Please bear with me.
1. With the new ECU, does the old 2 wire voltage regulator remain ?
2. The new ballast resistor is about 1/3rd smaller than original, does either work with electronic ignition ?
3. do you remove the old wires to the ballast resistor from the terminal block and install the new ones there ?
I am sure to have at least a couple more questions as I work to complete this conversion.
Thank you
PS, 1971 440 HP engine in 71 charger.
Thank you
