KCbelvedere
I have a thread stripped on my 727 where it mounts to the 440 on the lower starter side. Should be a 7/16”-14 be the threads are toast in the transmission case. This hole being all the way through the transmission case can I insert a heli coil from the back side fine? Or do I need to pull the transmission and insert the heli coil from the front of the transmission?
