Well, I ain't no Rocket Surgeon that's for sure. And I suppose someone with an engineering degree built it as a complete kit. You are correct in the easiest fix would be to chop a section off the cowl. Test fit to see how much the arm linkage clears by?
How much room is in the front - to radiator? My hot rod spidey sense says one could easily cut .75 - 1.25 inches off that circular motor mount and reweld it to the rear sector.
Boom engine forward.
Same thing with trans mount.
How this all affects other components will require that aforementioned engineering degree.
